I have an 1987 Starcraft SS160 with a 1983 Johnson 70 J70ELCTE (20"). Transom height is 20-1/2" from bottom of keel to the top of the transom.
The transom on this boat has never been drilled because it had a 1976 Evinrude 35HP with the hand tightened transom mounts. The transom is absolutely pristine with no holes for a reference point! Needless to say, I don't want to just start drilling into this thing. I want it done right the 1st time.
So here is where I am at currently at. I have found the center of the transom, I hung the outboard directly onto the transom, traced the transom bracket holes onto the transom skin and was ready to begin drilling.
I then read/watched a few posts/vids about setting the proper height...and then the confusion kicked in!
Do I just drill the upper most holes and then adjust the height from there? From what I can tell, I will end up needing to raise the bracket to the 2 or 3rd hole in order to get the cavitation plate above the lowest part of the keel.
Also, do you guys recommend putting some type a material between the transom bracket and the transom skin? Polyethylene/PVC board, Aluminum plate, Wood (not pressure treated), etc...?
I hope this all makes sense. Any help would be appreciated. I can't find much info on drilling and mounting an outboard on a brand new aluminum boat transom (like mine) using an 80's outboard.
