Re: boat identification/omc stern drive help
Welcome to iboats.<br /><br />That would be referred to as a "Stringer". I believe the Cobras came out in 1987. The one advantage they had was that they swing way up. That's about the only one I can think of, except the steering is gear driven greatly reducing steering wheel torque. Those have ball gears at the transom to transfer the power to the drive. If they're more than half wore out, they need replacing. If you ever remove the drive, you have to make sure the ball gears align the way they were or the cogs wear off very quickly. There are 4 places to put gearlube in those. The upper and lower halves of the drive are separate and need draining and filling separately. There's also a place for gearlube where the shaft passes thru the transom. The fourth is the tilt gearbox on the outside on the portside. That should slip the drive to the Down position once enouth throttle is applied. There's a clutch pack similar to a motorcycle's in there. Water gets in and things rust up.<br /><br />A set of ball gears is going to set you back about 300 bucks. They had two different models as I recall. The 400 and the 800. I believe anything with a V-8 got the 800.
