so i bought an older baretta with a 3.0 merc. boat hadn't been run in over a year and messed with it some and got it running pretty good at the house and put a new impeller in it . So it still had yr and half old gas in the tank but it did run off this stuff so i topped off the tank wiht 91 oct gas and headed to the lake. so i putt putt it around for a half hour or so and we bust out the tube. It's still sputtering a little but i figure it's the gas and it still get up on a plane and has descent power. well while pulling it completely dies and once i came to a stop it fires right up again go a little bit then it happens again. so i lift the lid and check for obvious problems check the battery and the positive side terminal is so hot it burns my hand????? check the voltemeter on the dash and it shows 11 volts. this is the old battery but i put it on a trickle charger and it held a charge so i figured it was good. also while i was checking over the gauges the volts were reading about 14 when we were driving so it is charging but now thinking back it shouldn't be charging that much. Next i turn the battery disconnect switch and sit for 10 minutes or so and try to start it again... it starts for a sec but has no response from the throttle and surges a sec till it dies i tried it again but this time a coulpe backfires. i checked for spark on one of the wires and nothing(weird since it does start sorta? i didn't have enough juice to keep trying stuff and got a tow in. i'm not sure what should be on my check list but i'm thinking
fuel filter
points (i never did mess with these at the house)
spark on all 4 cyl
and not sure what about the super hot positive wire??? think it's grounding out somewhere and draining the battery and the alternator is trying to compensate with the full 14 volts
if so what should i check first
thanks to all that reply
fuel filter
spark on all 4 cyl
