Boat lift, Shoremaster 3010 (3000lb capacity). Lifting a Reinell 198FNS (3060lbs)
Saskboatguy
Hey guys. Looking at purchasing a boat lift, used. I have a Reinell 198FNS, 3060 according to specs. The issue is I can get a 3000lb shore master for quite a bit cheaper than a 4000lb shoremaster. Found a few used every once in a while. Never had a lfit, how "exact" are the weight restrictions. Is lifting a 3060lb boat on a lift rated for 3000lb going to be a big issue? Do I need to consider going for the 4000lbs even though they're often $2,000 more?
Any help is appreciated :)
Ayuh,...... I wouldn't,..... Yer boat weight will be atleast 20% higher after it's gassed up, 'n loaded with toys,.....
Your boats dry weight is 3060#. That is before oil, gas, gear, cover, toys, etc
