Irv964
- Joined
- May 3, 2008
- 315
I have a Naylor 2400Lb boat lift and when lowering the boat into the water, the lift wheel is very stiff/hard to turn.
Just curious if anyone has had a similar issue and if so, how did you rectify the issue?
I assume the brakes are holding up and not releasing and I also assume this is due to corrosion/rust of some sort?
The winch itself looks identical to this one, (below) but my problem is, I have never opened one of these up before so I have no idea what I am up against?
Just curious if there is much to it, what I need to look out for, and can I screw this up if I am not careful?
I have moved the wheel up and down numerous times from real short back and forth bursts to much longer ones but nothing I do is freeing it up.
Replacement Boat Lift Winch | Dutton Lainson 3500lb
