Beachbum49
- Joined
- Apr 21, 2002
- 21
I've got a 21' Wellcraft CC which I keep in a lift under my deck. The lift has a 3/4 hp, 1725 RPM motor with a small pulley. A v belt from the motor turns a large pulley attached to a worm gear. The worm gear turns a large gear which is fastened to a 2" pipe which has cables attached to 2 slings. The electric motor has burned out. A friend gave me a new 1/2 hp, 850 RPM motor. He told me to use a larger pulley on the motor to make up for the difference in RPMs. I can see where that would probably work but I am concerned about the hp difference. Does anyone here think it will work or should I just spring for the 200 bucks for a new motor? I have no idea how much the boat & 75 gal. of fuel weigh. Thanks for you help.
