boat listing?
roger777
I have a 24' wa robalo with twin 150 yamahas.When I get around 3500 rpms the boat will start to list to the starboard side.. I had hydra foils on and took them off it seems about the same.. The skegs are not bent or chipped.. One thing I did notice is the gaps between the transom brackets of the motors and the top of the transom are not level.. Meaning the mounting holes might be a little off..I dont know if this could of been a mistake at the factory or if the holes were drilled by someone who did not know what they were doing..port side of port motor about 1/2"gap, starboard side of port motor has about 3/8" gap. port side of starboard motor has about 1/4" gap and starboard side of starboard motor has about 1/8" gap..
Is there a way to measure to see if the motors are both aiming straight. I installed a tie bar and had to eye it out..I know that cant be the right way..
thanks
