paczowski123
- Joined
- Mar 20, 2011
- 115
well as it says my 1998 bayliner with a 4.3 190hp mercruiser will misfire and bog if it has sat for a few days. However it only does it on the initial attempt to accelerate, it will slowly clean its self out and from that initial time it will run fine for the rest of the day. It will also only do this if it has sat more than a couple days otherwise it will not do this. for instance if i use it lets say after two days it will be fine, but this past week it sat all week and i didn't use it and it did it. I tried to accelerate and it bogged down and slowly accelerated and then cleaned up and was fine the rest of the day. Does this sound like anything i should look into, maybe a bad distributor, plug or wire? that maybe needs to warm up in order to preform better? Or maybe a partially clogged port on the carburetor? Has anyone experienced anything like this? this is my first I/O so idk if its normal to run harsh upon warm up or if it seems to be an actual problem?
