mclark4642
- Joined
- Jun 21, 2008
- 13
hey guys,
I asked this question about a month ago, so I apologize for starting a new thread, but I thought I'd ask it again, in a "cleaner" method.
This is a 1972 Johnson 85hp outboard motor.
I took my boat out about 6 weeks ago, and everything seemed to be working fine. I stopped and fished for a while, but when I started it back up and moved the shift gear into forward, the motor reved up but would not go forward. Suspecting I was stuck on a stump or something, I put the gear into reverse and backed up about 15 feet, and then put it in forward again, and it still wouldn't go forward! When I got the boat back home, I put the water muffs on and ran it in forward and reverse, and the propeller seems to turn just fine.
On the previous post, someone suggested that I might have "spun the hub". I took the propeller off and looked at the rubber hub on the prop and everything seemed to feel tight and snug on there. I also checked to see if there might have been any tangled line or anything, but I didn't see any.
Does anyone have any suggestions on what else I might need to look at, or could this be a bigger, more expensive problem?
Thanks!
Thanks!
