We took the boat out today, after putting on a new waterpump. Boat ran great, had no problems at all. Temp stayed about 165-170.After about three hours of run time I noticed the belt starting to squeak at a little above idle.I stopped and checked it out, alternator belt was extremely loose and was very wore (I just replaced the belt last week) I tightened the belt up and headed for shore. While waiting on the trailer to get backed in the water I run the boat up the lake just a little bit so I could circle around, noticed a squeak at higher rpms this time and temperature quickly started to shoot up, I ran about a quarter throttle back to the ramp, about 50sec run time, the temp. got a little over 200. As soon as I got close enough to the trailer that I could coast the rest of the way in I shut it down. The alternator belt had broke, this belt also spins the pulley that turns the sea water pump. Should anything be checked? Will I be alright. The boat never made any funny noises or I didnt notice any smells besides burnt rubber.
What is causing the belt to smoke and wear so quick? Alternator bearing bad possibly?
