beckoning
- Joined
- Dec 15, 2010
- 161
This is going to be hard to explain, but I'll try. I have a 19' aluminum boat weighing a little less than 2,000lb with motor, kicker, 25gallons of gas, and gear. I need to know how to adjust my rollers so the bow comes into the rubber V, and the bow eye comes under the roller.
My tongue weight was about 1% and pulling was dangerous. To make it between 7-10%, I moved the winch bracket forward on the tongue about 8-10", and moved the rear roller rack forward about 10", otherwise the rear-most rollers would hang out beyond the back of the boat. All seemed good. I put the boat on the trailer and the tongue weight is about 160lb. However, for some reason, the boat rides high on the rubber V so it is impossible to have the winch strap be below the front roller. I can't seem to pull the boat all the way into the rubber V at the front, or have the bow eye come in below the roller.
I know this is confusing, but any thoughts would be helpful so the boat sits on the trailer more balanced instead of trying to be nose high.
