Hi guys,
Brand new here, Here's my situation...
Bought a boat recently, got it for almost nothing needing work of course.
It's a 1988 Glasstream Seaquest, an apparently rare boat, because there is almost no info on it on the web. The boat is 26 ft. in length. I do not know the weight. The boat has a 898 drive in it. I bought the boat minus the engine. The guy threw in a 302 needing building. I've got the 302 at a mechanics right now being built. He is building it to put out 250+ hp.
After doing a little research, am I correct in the 898 drive goes with a chevy 350?
If this is so, will it work with my engine?
Gearing and all? or do I need to get a 888? or a newer drive?
I've got all the main components, except for the carb (2 or 4 barrel) and a few other things (distributor, will get marine version) My engine builder has experience with marine engines and will be putting in brass freeze plugs etc.
We've already replaced the transom on this boat and will be painting the whole thing as well as reworking the trailer, and having the upholstery redone. Too far into this thing to turn back. Any advice is much appreciated. I would post some pics but my ISP is down for some reason.
Thanks..
Thanks..
