Boat pulling left .Need help fast
mattsanders
If my 70 hp is pulling the stick steering left Boat will circle left) Haw should I adjust my trim tab? Please explain this. Im going out tomorrow, and need to fix this tonite
ezeke
Re: Boat pulling left .Need help fast
Turn the rear of the trim tab in the direction that the boat is turning. Use small increments until you have correction.
The trim tab works by deflecting water that is moving from the propeller.
ezeke
I use OMC/BRP Factory service manuals - works better. Click the thumbnail please.
You usually find these instructions at the end of the gearcase sections.
mattsanders
Ok I will try that. If it still pulled hard left when centerd, should I put it all the way over to the left?
ezeke
Adjust in small increments until it works correctly.
F_R
Read the second paragraph in that picture. Might save you some frustration when it doesn't work no matter where you put it.
