I have pontoon boat with 92 90HP Force. Boat was pulling fairly good to the right. I checked the exhaust/trim tab on the motor and it was all the way to the right(if you are facing the boat from the back). would this make the boat pull right or left?
Should I push it all the way to the left(again if you were facing the boat from the back)
Skeg does not look bent
motor might lean VERY slightly to the left but I can say for sure on the trailer. Is there a way to check if the motor is perfectly level on a trailer?
thanks
thanks
