Re: Boat pulls to one side, wheel alignment?
Lets try this again.<br />Looking at your engine from the transom, it turns ccw, not the prop, the engine. The engine torque is what's causing your boat to pull to the port. What you need is trim tabs that mount on the transon, even with the bottom. These can be electrical or hydraulic operated. Applying starboard (right) trim tab will counter-act the effect of the engine torque pulling you to the left. You'll have to do some research to determine what size trim tabs you need. The small fin on the lower unit is to offset prop torque, not engine torque. The more dead-rise and/or horsepower a boat has, the more susceptible it is to engine torque.<br />Keep us posted.<br /><br />c/6<br /><br />Hooty<br />Keep us posted
