We bought a '98 Larson 206 Lxi BR (20' I/O) and we've taken it out 4 times or so. We've noticed that the boat seems to want to pull to the right. I didn't notice this the first time we took it out, but I've noticed it everytime since. We happened to install a second battery (on the same side as the first battery) on the right side of the boat and initially thought that may be the problem. We installed it after our first trip out so the timing seemed right. But even though I moved the cooler and tubes and heavy items to the other side of the boat (instead of center like we had them) it doesn't seem to make any difference. Even with my hubby (250lbs) on the left with the coolers and me (100lbs) driving nothing makes it change. Soooo... I'm thinking this has nothing to do with the battery? The boat does have a max occup of 11 and some crazy weight capacity so it's hard to believe a 60lb battery would throw it off anyway...
Thought number two... we managed to run the boat aground
coming out of the sass river and luckily hit only mud. The damage we saw to the boat was the black prop is now silver and there are a few small nicks in the edges of the blades but nothing is bent. We both think the boat pulled to the right before this incident though....
What else can we check???
