Boat rebuild questions.
parrisw
Ensign
I have a 1964 Johnson Tri-Hull, and this winter I'm going to rip out the floor and make sure all is ok. The floor has a soft spot, and want to check the stringers, I suspect they are not glassed in due to the age of boat. The transom is bare on the inside just has a coat of paint, and someone has done some shoddy fiberglass work where the floor meets the transom in the center where the well is. Can I leave the transom alone? and glass some new stringers/floor to it? All the transom that I can see looks ok. Also am I ok to leave the boat on the trailer when doing this work. Hope to get started in the next month or so.
Thanks
Woodonglass
Re: Boat rebuild questions.
Welcome to iBoats!
Let me suggest you start by reading this thread. Andgott has done an excellent job on "Gutting" his boat and then restoring it to a pristine state. He is still working on it but is well on his way to success. You will learn a lot.
http://forums.iboats.com/showthread.php?t=355668
You may or may not have to go this far but you will KNOW what you may have in store for you. Usually when the Deck (Boats don't have floors)has soft spots the stringers and transom are bad too.
I'm just sayin...:D
parrisw
Ensign
Welcome to iBoats!
I'm just sayin...:D
Sorry "DECK" LOL. Yes your right, you don't know what you got until you tear into it. Thanks for the link, I'll read through that thread!
Will
parrisw
Ensign
What about supporting the boat while the deck is out? Is it ok to sit on the trailer or should I make a bunk?
Woodonglass
Either way will work. A bunk will significantly lower it and make for easier access but you can leave it on the trailer too! Take some measurements as it sits now so you will KNOW what the finished dimensions should be. You can make some interior braces if you think it is starting to warp on you.
I'm just sayin...:D
parrisw
Ensign
I'm just sayin...:D
Ya thanks. It will also make more room without the trailer as well.
Thanks
