(First, let me say that I hope the following is not true because I definitely expect to buy my first boat this season and I?m not mechanically inclined.)
I?m getting the impression?and perhaps it?s an erroneous one?that boat reliability is vastly inferior to that of autos.
In my search to buy a boat, I?ve had the following experience. Of the three boats on which I?ve done water trials each has had a problem. (Each boat was a mid eighties model.)
One boat cut off several times at idle speeds.
One cut off once at idle speed.
The third wouldn?t start. After a new battery and a successful trial, the boat wouldn?t start the next day.
Even though a boat engine is essentially a modified auto engine there seems to be a vast difference in what a boat owner expects as regards vehicle reliability.
What do I mean? Well, if a car owner paid five thousand or more for a car, I think he?d do so with the expectation that when he turns the key the vehicle will start. Not maybe, not might?but will start.
And not only that, the auto owner expects to turn that key hundreds if not thousands of times and fully anticipates the vehicle will start on each and every occasion.
Is boating any different? Why?
Finally, how would you answer the following:
When you turn the key to your boat, you expect:
A: The boat WILL start and WILL continue to run until I shut it off.
B: The boat MIGHT start and MIGHT continue to run until I shut it off.
C: The boat MIGHT NOT start and MIGHT NOT continue to run until I shut it off.
