boat repair
wallyiv
does anyone know anyone in maine that does boat work on the side? i live in lewiston.
thanks
cr2k
Re: boat repair
You might specify what type of boat work. Fiberglass, mechanical, electronics, etc.
roscoe
Re: boat repair
try craigslist.
If no luck, post that you are looking for someone.
Just check them out before you let them work on your boat.
oops!
Re: boat repair
usually any one that works "on the side" ....is ...well.....
ya get what ya pay for.
check your local dealership.....ask for a good mobile mechanic or hull repair person
wallyiv
Re: boat repair
I’m thinking that i need my carb cleaned. It has a hard time starting when cold. Also when we were on the lake when i give it full throttle it Boggs down. I have work on small engine carbs but never a car or inboard carb. Are they hard to clean? Is there any post that would help me through a cleaning?
wallyiv
Re: boat repair
sorry i havent been giving much info. i have a merccrusier 5.0 with 2bbl its a 1993. i changed out the filter again today and took it to the lake. it seamed to run better but still boggs down when i try to pin it when i get it plained out. im not sure where any adjustments are to help with this issue. any ideas??
rickryder
Re: boat repair
I would try the carb rebuild section of the service manual...
