BOAT SEATS cobia
Pam C
Does anyone know the style of rear seats that where in a 1965 Sea Queen? I am trying to figure it so that there is easy access to tanks/battery plus not too tall to be able to climb in from the rear ladder.
tashasdaddy
Re: BOAT SEATS cobia
Pam, i don't know about the sea queen, but the bowriders, had to drop down jump seats. and a curtain to hide the mess.
Pam C
How funny. I have my boat painted and re-wired and carpeted. Just a few finishing touches. Will have you post pixs this week. I can do all this to a boat but can not figure the pix on this website.
I wish Barnacle Bill was around or the other guy with the Cobia Sea Queen.
Can seats be spray painted?
tashasdaddy
the bases yes, vinyl no. used a spray primer first.
Pam C
a spray primer on the seats? too? or no period? I was able to use all of the hardware and swithes, just new wire. It is a beauty. Thanks again for your help and the offer to bring her down. I will post the
pix soon to you. Does this boat need a white light in the back? It has an all around white masthead light.Can a bilge be put in this and you mentioned the steering cables beeing dangerous. Could you expound? Thanks
tashasdaddy
clearify what you want to paint of the seats. a bilge can be added easily, mount the pump, wire it, then drill a hole on the control side of the side up high, mount the fitting and hose. the reason for the control side is so you can see it.
steering you have a 110 hp motor, the cable steering was original equipment, as there was not an alternative. these cables wear, deteriorate, have to be periodically adjusted. if the cable jumps the drum, you loose all steering, i've had it happen. for your and everyones elses safety, i highly recommend you install the teleflex no feed back rotary system. it will last 10 -20 years.
Pam C
please resond asap
I tried to install the captains and mates seats tonite and the screw tried to come out the side. Now obviously it was too long but now what? I put some silicome over it but is it ruined? I t is about 2 1/2 inches above waterline.
Now What? Is the silocone good?
tashasdaddy
not silicone, clean all of that off, and use a product called marine tex.
