Will191
- Joined
- Oct 16, 2011
- 8
1) Performance issue you are trying to correct.
I'm new to boating having bought this boat two months ago. What I'm trying to correct is that I'm unable to get boat to plane. Both motors seem to run strong, good oil pressure, but it just seems to churn water and won't get going. Trim tabs (Bennet) function but it still won't plane. There is some buildup of gunk on the bottom of boat where it sat in fresh water for several years prior to purchase, and I'm planning on having the bottom painted, but haven't yet. I'm not sure how much of a factor this is and I haven't been under the boat to see how much is there. From the sides it looks minimal, but I don't know enough about boats to really judge. One thing I'd like to know is what should I expect speedwise from a boat like this. I've experimented with the trim tabs and pitch, but it just seems like all she wants to do is plow.
2) Current prop manufacturer, model, aluminum or stainless as a minimum.
Solas 4-blade aluminum. Some discoloration on prop, some pitting around the edges, but generally appears to be in good shape. No notches or dents that I can find.
3) Current prop diameter and pitch (required).
14.5 X 17
4) Wide open throttle RPM and speed with an average load (very helpful)
4000rpm yields 14mph. Load: two adults, two children. approx: 580lbs. Boat has Cruisair air conditioner, Onan 3.0 generator, fresh water (35gallons, I think) 100gal of fuel. I guess that's my average load.
5) Engine/drive make, model, year, and HP
Twin 3.0 Mercruisers, 1986, 140hp each (181cid), drive I/O.
6) Boat make model, year, length and weight
1986 Chris-Craft Scorpion 266. I've been unable to locate an authentic owner's manual for this boat, but what I've found on iboats says the boat should weigh 5200lbs dry. I'm not sure if this is for two motors and all the accessories, like the generator and a/c, so maybe 6000lbs. All the boats I've located on the internet, approx 4, all have a single V-8 Merc 260, and don't mention accessories but do reaffirm the 5200lbs. Draft is approx 2 to 2.5 feet. Beam is 8.5ft.
Any help/advice would be greatly appreciated.
14.5 X 17
