Hi,
I've posted before but since have done several tests to rule out certain problems.
The problem is that at a certain speed/rpm (7mph) the motor stumbles and will stall if you continue to push forward the throttle. It usually backfires through the carb when it stalls. The problem only happens under load. In neutral the engine rev's up fine with a little lag in response.
I understand that this is usually a fuel lean situation in the engine. I did check compression and have 135-140psi straight across. I have already rebuilt the carburetor with special attention to the accelerator pump and power piston and valve, changed the distributor, plugs and wires. I recently changed the fuel filters. The only thing I've yet to confirm is the fuel pressure being delivered by the fuel pump and the manifold vacuum but I can check that once I buy the proper equipment.
I first noticed the problem a year ago but you could usually get past the rough spot after a few tries. The problem has progressively gotten worse and now it never gets past the rough spot. Other than the fuel pressure and vacuum is there anything else I'm missing here. The engine is mechanical advance on the distributor but I replaced it so that should rule out that. Can the carburetor still be bad even though I rebuilt it and it looks very clean. Power piston works fine when I apply vacuum to the port. Any help????
