Boat stalls when put into gear? 50 hp Johnson
E_S_A_D
So, we just bought a used boat with a 50 hp anniversary 50 years Johnson outboard. It was running fine, but from the get go we have had trouble shifting it from neutral to forward or reverse. It simply stalls. So we have to start it in gear.
Now today, it did not get us back to shore. It idled fine. As soon as it shifted into gear it stalled.
Any ideas? One person mentioned something about a shift interrupt? If this is plausible, is it a major / expensive repair?
Thanks all.
Daviet
Re: Boat stalls when put into gear? 50 hp Johnson
Start with the basic checks, spark, compression and fuel delivery. Make sure the idle is set to proper RPM.
You should not be able to start the engine in gear, you might want to check out the electrical system as to why it does.
E_S_A_D
It was just at a mechanics shop. New plugs and a rebuilt fuel filter that had a leak. Ir ran yesterday great, but just doesn't like being put in gear. Reverse or forward and it stalls. Idles fine. This has progressively gotten worse. It does let us start it in gear.
Compression, spark, and fuel should be all okay.
E_S_A_D
Also, when it was recently in the shop I noticed that he used this electronic 'gun' type thing from a distance while it was running. What was this instrument?
Daviet
What is the idle speed?
What is the model#
It could have been a temp gun to check the block temp when running.
E_S_A_D
What is the model#
I'm really an engine novice. I don't know idle speed, model number I'm not sure. It's a 50 hp 50 anniversary Johnson. Oh a temp gun, interesting.
When it was at the mechanic he said the engine is in good shape. We also revved the engine with the top off by hand and it reves fine, just stalls upon putting in gear.
I hope we didn't buy a bad engine.
Daviet
When it was in the shop, was it running on a hose or in a tank?
My best guess is the idle needs to be reset.
E_S_A_D
Is this an expensive issue, Daviet? If it were the idle? In the shop it was hooked to a hose.
It ran great and the fuel pump was rebuilt, because it was leaking. Once in gear it runs great, but on this last time out on the lake it wouldn't let us get it into gear.
Is it expensive to have carburetors rebuilt or new ones put in? Any ideas?
Daviet
If the idle was set while running on a hose, it might be to low. The idle should be set with the engine runing in the water (backpressure). To set the idle speed up all you have to do is reset the idle screw on the side of the engine, not hard to do if you know where it is.
Do you have a manual for your engine?
E_S_A_D
Yes, I still have the manual. I the carbs need cleaning, is this an expensive issue? It's an old engine and we only paid around $750 for the whole boat/ trailer/ engine. Now, I'm worried I'm going to be putting that much back into it!
