I have a 1995 Mercruiser 4.3LX with a 4 barrel and Thunderbolt IV ignition. I am not sure what the problem with it may be, however, it is hard to start when cold. It will start first crank initially after 2-3 shots of prime, however, will only run at idle for a minute or so and then die. This is when the fun begins. In order to get it to fire again I end up cranking and cranking the starter and then finally it will fire and I have to immediatley get it up to about 1500 rpm or else it will die again. Once the temp is up to 100-150 it is fine afterward. You can shut it off and and start it no problem as many times as you like as long as it doesn't sit for more than an hour or so. If anyone has any ideas it would be great. I think it may be a problem with the choke , however, not sure.<br /><br />
