t2sunquan
- Joined
- May 8, 2012
- 35
I have a 1980 200hp OMC that ran, full throttle or idle (planning/cruising on water) for about 30 minutes then all the sudden it just died in the water(it was a very expensive tow), it would not restart but here's the kicker, when i trailered it... it started right up on the second crank. Now today i went to bring it out to the lake and i started it on muffs before i left to warm up the engine, ran fine. I dropped it into the water and it would not run, i checked the carb.. had fuel running down it when i moved the throttle, and spark seemed to be ok. Last month i did a compression check and everything checked out ok, I'm wondering if water is getting into the cylinders while it is the water. It has 35gal of fresh gas mixed with Startron in it too. It just seems like it tries to start then just sputters down and dies while it is in the water regardless of throttle position, I cannot even get it into gear. The carb was also just rebuild a couple weeks ago, along with the fuel lines, fuel filters, and anti-syphon valve, i would imagine fuel pressure is ok as i cranked it over with the hose un-attacted and it sprayed everywhere. I'm pretty much at wits end with this boat.. anyone faced this problem before? or perhaps some insight as to where i look next?
