Re: boat sunk help
thanks found it pushed the button and it started with the key.
This is what happened to me. Brought out the boat '86 85hp Force. After some low battery problems I got the motor started with a different one. Motor idled great but when I put it in gear it quit. I went to turn the key again and nothing. Horn and trim/tilt worked but absolutely nothing when I turned the key to start it. So after checking some wires I gave up and brought it home, heartbroken, as I had just replaced the waterpump and done all this work on it. So after some reading around on this site, i discovered these motors have a circuit breaker. I didn't see anything about it in either of my manuals! So I walk outside at 10pm, pop the hood, find the tiny little breaker, push on the button and "click", a smile came to my face. I walked up, turned the key for a spit second and low and behold the starter engaged! So, back to the lake tomorrow for another try at her maiden voyage.
Seriously though, if it wasn't for all of your guys' input and smarts on this forum, it would have been back to the shop for me, several times. You've all saved me hundreds of dollars on fixing multiple things, I can't thank you enough! You guys are awesome.
Thanks from a poor college kid,
Jon
