Re: boat tilt to the left
Hammer,
You will want to install the smart tabs about five inches from the end of the transom. It is easy to adjust the boards to avoid the tabs. As to the transducer, mine is flush with the bottom of the boat and rides up on the bunk.
Your boat would probably use the -40 size.
Compcrasher86, If you are throwing a large rooster tail, your engine may be trimmed too far back.. If you have a manual adjustment, set it in pin one and see how it rides. Smart tabs will smooth out the ride and help the boat get on a plane faster.
Regards,
John
