Boat trailer electric brakes
Cruize
I am looking to add brakes to my boat trailer and will probably go with electric.
Are there any particular brands that handle water better or worse than others?
Any brands to shy away from?
Thanks in advance.
batman99
Re: Boat trailer electric brakes
Dexter brand makes the most popular electric brakes.
I hear Quality brand from Princess Auto is lower cost Dexter brand compatible. Meaning, their Quality hubs fit Dexter brake assemblies and Qaulity hubs fit Dexter brake assemblies.
Was told its best to always use "matching" company Brake assemblies and "matching" company drum/brake hubs. Try to avoid Dexter brand on one wheel and non-Dexter brand on opposite wheel. Just like its best to use same brand of rubber on each axle / rim.
For me, I like Dexter brand the best. IMO, they seem thicker metal and hold majority of market share. They may cost $10 more for each brake drum or $10 more for brake assemblies. But in the long run, I hear paying slightly more for Dexter brand is worth it.
Hope this helps...
MRS
Dexter here on three trailers all fresh water and alittle salt just rinse good after dunking no problems so far.
BobGinCO
Do your axles already have brake mounting flanges? If not, you'll need to replace your axles.
Cruize
Thanks for the responses. I read as many posts as I could on the forum, but didn't find any mention of manufacturers. I had the Dexter auto adjusting brakes and the brake drums w/ EX Lube caps priced out.
My one and only axle (wish it had a second) already has the mounting flanges, so the axle is good to go.
I do not plan on launching in salt water, so heavy corrosion should not be an instantaneous problem.
batman99
E-Trailer sells:
Dexter brand
Redline brand
TruRyde brand
re: http://www.etrailer.com/dept-pg-Trailer_Brakes.aspx
Princess Auto sells:
Quality brand
re: http://www.princessauto.com/pal/category/1100-310-005-025-005/Electric
Northern Tool
Tow Zone brand
re: http://www.northerntool.com/shop/tools/product_200514148_200514148
iBoats:
Atwood brand
Tie Down Engineering brand
re: http://www.iboats.com/Drum-Brakes/dm/view_id.341263
Before buying, do "double / triple" check brand and bolt pattern. Some drums are only for electric, some are only for hydraulic and some drums can be used for both. And, double check rim's bolt pattern using: http://www.trailercanada.com/pdf_documents/boltcircletemplate.pdf
Hope this helps as well...
ufm82
I had the Tie Down GalvX drums on my trailer (single axle) and had the trailer for 5 years with no issues. I installed the kits myself and was careful when routing the wires but it wasn't brain surgery. I installed a progressive controller in my truck that I loved. When you hit the brakes the trailer brakes engaged gradually instead instantly. This made for very comfortable towing- no jerking or yanking, especially when you were in traffic. Can't remember the brand though. I thought electrics were the way to go for that trailer. I currently have hydraulic discs on my current trailer and greatly prefer them over the electric drums...
