Boat Turns By Itself
nofishjoe
Ok Have a Boat and a Motor. Just a start but hey it works..... uh anyways. Running at full speed with a 60 Horse Johnson on it likes to go right withut any help. Now trying to turn it left is a chore because it pulls hard.. Is the propellar off balance?
magster65
Re: Boat Turns By Itself
Not likely but try adjusting your stabilizer(?) zinc on your skeg. I can't remember what that one's called. That'll help.
OBJ
Lemme help ol' magster out.....(probably got the new son on his mind)....it's called a trim tab. Look for the tab under the anti-cav plate right above the prop. Loosen the retaining screw and turn the tab in the direction of turn, usually to the right looking from the rear of the engine.<br /><br />Outboards naturally torque right. The trim tab will compensate and take most of torque out.
splugeeman
The Big Dog is right again.....the trim tab will need to be tweaked just right...I have had to do it a couple of times on mine. It not a large adjustment but it really makes a difference
