Keith7481
- Joined
- Aug 21, 2005
- 125
I'm considering buying a 2003 GS249 but am concerned abou the tow weight. I would probably pass on the boat if I can't tow with my current vehicle rated for 6200 lbs. I took this from a previous post:
Weight:The website lists the boat (with 5.0 engine) at 4437lb. After towing the boat for two seasons and about 7,000 miles, I had it weighed. On the trailer, the weight was 7260 lb. Subtracting the weight of the trailer, this leaves 6020 lb. Subtracting the published weight of the boat leaves 1583 lb of fuel, water, and miscellaneous". According to my calculations, gas and water should be under 600 lb. Clearly, the published weight is much lower than the actual weight. Because of this, the dealer furnished an undersized trailer and I purchased a vehicle that's marginally rated to tow the boat.
So, based on that post, I'm wondering if anyone out there has conflicting information about the weight of loaded boat and trailer? how likely is it that this high weight could have been a fluke? Thanks in advance.
Keith
Keith
