I hope someone can help with this problem. I have a 1970 16ft Sportcraft C-Gull and I suspect I have wet foam. I have so far figured my weight on truck scales at 1098lbs. Their are two items that I don't have weights on is the metal plate on the rear to re-enforce my transom and two pieces of plywood. One piece it part of my deck, I do not yet know if it is over the original deck or is the deck (winter project). The other smaller piece is about 4ft X 5ft placed on top of the deck piece to support my fishing seat. I did not take out the regular seats (lounge type) out of the boat. Everything else was removed.
I have several questions I hope someone can help me with.
1. What was the density of the foam used in the early 70's? I know they have pourable foam as light as 2lbs/ft cubed.
2. Based on what little I can find I have have 100-150lbs I can't account for. Am I in the ballpark.
3. I have a '77 Johnson 70hp the prop is properly matched 15in @5500rpms average 28mph sometimes hit 30mph (gps). I had a similar style boat as a teenager except it was 18ft with a 50hp and would hit 35mph(no gps back then).
I just would like to know before I start tearing into it this winter. Kind of got hooked on this boat with all the elbow grease I have put into it and the headaches she has given me.
