ok im lost. I have a 1987 baretta 27' with a rebuilt 460. performance distributer, carb, ect... was told it should do about 53mph. here is the problem. when im am crusing at about 5mph everything sounds great. when i give it wot the boat doesnt go any faster. There is no slipping involved. the engive is tuned up great and it is revving good. my tach is broke but it def is getting up there in rpm's. it feels like im pulling a ton of weight and it will not plane out at all. the prop is a 141/2x19 so i think thats good. whatever the problem is seems to get worse and worse every time i use it. i do not have any bottom paint and after just a few weeks in the water i have a ton of barnacles on the bottom. could this be slowing the boat down this much? could it be the trim tabs not working correctly? i have a top speed of 15mph with only 4 people on the boat and the engine is working hard to get there. also a little pinging at wot. should i be using a higher octane? I adjusted the timing so its not to far advanced.
