Boat wiring
larry1592
I apologize for posting this question in the wrong forum but I now believe I am in the right forum. Question: I am trying to rewire my 1979 Grady White 24' Weekender. I want to run a 4 gauge wire up to a breaker and then to a power buss bar for all of my accessories, lights, electronics etc.. . The switches are on a panel and are fused also. Question, do I run it from the battery switch or directly from the battery. I have two switches, two batteries, and two engines. The reason I want to run the 4 gauge to a buss bar is because it is like Spaghetti under the dash. My intention is to get rid of the old wiring an replace it with new. Please advise.:rolleyes:
lowvlot
Re: Boat wiring
I would run 2 8awg wires instead. Then split up the circuits. important functioning circuits on one and not so important on the other.
Luhrs28
Re: Boat wiring
I would run your main + wire from the battery switch, except have your bilge pump(s) wired directly to the battery with a fuse. Ideally when you leave the boat docked everything should be switched off except for the bilge pump.
jspriddy
Re: Boat wiring
My boat's wiring also looked like spaghetti, not only under the dash, but in the battery compartment as well. Mine's a 15.5 ft. bass boat so the wiring would be much simpler, hopefully.
What kind of bus bar and breaker do you have? I need both these items.
John
AviatorJim
Re: Boat wiring
I concur. Definitely run it through the battery switch, but I would run the bilge pump through a switch also, but a different circuit directly to the battery. You do want to have a way to cut that off when you have it on the trailer. I have 2 circuits from the batttery to the electronics bus, one off of each battery. I only use one to power it, but it gives me the option to run them off of either engine if one breaks down.
--Jim
larry1592
Re: Boat wiring
Thanks for all of the replies. John, I got a Seachoice 30 AMP breaker and a Seachoice 10 gang terminal block:):)
jspriddy
Re: Boat wiring
Thanks. I guess a 4 or 6 gang would be all I needed-2 fish/depth finders, bilge pump, aerator, and nav lights.
Is your breaker manual or automatic?
John
larry1592
Re: Boat wiring
John,
It looks just like a home circut breaker only smaller. I can toggle it on and off I guess if I needed to but I am going to wire it from the battery switch. The bilge is going direct from the battery to a breaker or fuse and will be on a switch. I think I pretty much am going to take all the other wiring out and see what new I will have to use. I am also going to make a schematic in case I don't have the right color wire. Talk to ya soon.
LB
jspriddy
Re: Boat wiring
...just like a home circut breaker only smaller. I can toggle it on and off I guess if I needed...
OK, that's my fault, Larry. I was confusing a circuit breaker with a battery switch. Not that I didn't know the difference, I just got them turned around in my mind. But is the circuit breaker going to take the place of a fuse (or several fuses), as it does in house wiring?
Taking out old wiring and seeing what works is pretty much where I am now. I think the guy that owned this before me just ran a new wire to the battery when something quit, and if he had 15 feet of wire and only needed 5, he just bundled up the excess. I've never seen such a rat's nest. I'm saving all the excess wire I'm removing. When I get done, I may post a picture of it. Wish I'd taken one before I started.
John
seabob4
Re: Boat wiring
What I do for a living. Take this...
And turn it into this...
With a little patience and know how, it can be done...
Silverbullet555
Re: Boat wiring
Man. I pride myself on my wiring, but DAMN! That is awesome. Wish all boats were this way.
jspriddy
Re: Boat wiring
Awww. Come on, Seabob. You just took a bunch of wires and threw them up there for the picture, didn't you? And you stole two of my little orange connector thingies, didn't you? That's OK, I'll have a pocketful when I get through de-wiring. I won't go so far as to say I'm "rewiring", yet.
Isn't it amazing the things people will do to keep from fixing something right? Don't check a fuse or switch, just grab a roll of that "red NAPA war, Charlene, and tie yore en' to the batt'ry".
John
seabob4
Re: Boat wiring
I have fun in bilges, too.
Before...
After...
When you gut everything, and start with a clean canvas, it makes things a lot easier...
jspriddy
Re: Boat wiring
Do you solder connections and terminals? I couldn't tell from your pictures. I always thought this was the "best" connection possible, but have read different somewhere here.
John
NYBo
Re: Boat wiring
1. 4 gauge to run the breaker panel is overkill. 8 gauge is plenty for the loads you're describing.
2. Use quality crimp connectors and a quality crimp tool.
seabob4
Re: Boat wiring
John
Soldering is allowed per ABYC in butt connectors in the middle of longer runs of wire/cable, as a solid joint is created, and the inherant flex of the wires/cables will be sufficient to withstand vibration. At mechanically terminated joints? No solder!
boaterinsd
Re: Boat wiring
John
FUNNY:D
i had to read this 2 times to get the point with the spellin, n all, LOL
jspriddy
Re: Boat wiring
Thanks, and I guess I've hijacked this thread and for that I apologize. But one more question-what is the reasoning behing not soldering mechanical terminal connections?
John
seabob4
Re: Boat wiring
John
Vibration. The same reason we use stranded wire on boats, not solid like used in homes. When you solder a connection, it in effect becomes solid wire. The close proximity of the mechanical connection doesn't allow the wire to move with vibration (unlike a butt splice in the middle of a longer run), and eventually the wire will crack where the solder joint is...
