Boat with no transom hooks! What to do?
Chris51280
Ensign
I got my 1990 Century bowrider about 2 years ago. There are no transom hooks installed. I do have 2 large eyelets on the side of the trailer. So what I did is, I ran a strap over the sun deck/ engine hatch to keep the boat from bouncing and have it secured to the trailer. This should increase the friction over the bunks quite a bit. The fron is secured with a chain and the winch going under the bow stop. Anybody else had a boat with no transom hooks? I know the strap is too small and a bigger one is being used now.
The collapsed bunk has been replaced and moved forward so it is flush with the transom
fetch
JimS123
In the olden days transom eyes were used with a bridle to tow a skier. Tying the boat down to the trailer was an added benefit. Those without them had alternate tiedown equipment.
In later years, with the advent of center mounted ski hooks (I see you have one) they were no longer needed for skiing, but still necessary for trailering. I can't believe your Century doesn't have them. (there are none under the swim platform? - you have to crawl down to see them?)
Regardless, it's an easy add-on. If you have access inside the boat to the transom (and thus can put washers and nuts on), a good SS eye only costs a coupleabucks. If no access, then what you are doing is appropriate.
many boats use the large strap across the aft end
however they are a bit wider (about 2-2.5")
jimmbo
Serious scuffing of the Gelcoat and damage to sunpads can occur from Straps running Port - Starboard. I guess Barriers can be placed on corners and sunpads to reduce it. As mentioned above, Tow Eyes, can probably added to most Transoms, even if some Glasswork is needed on the Transom for strength
Chris1956
Gee, you do have rear cleats. Use them to hold the boat to the trailer.
JASinIL2006
Seems like a good way to snap off a cleat or possible tear it clean out of the hull. Not much reinforcing in the fiberglass below a cleat, usually.
JimS123
That's also why you don't ever use a cleat to tow anything.
Been there, seen that.
Chris51280
Ensign
My gelcoat isn't the best and I will probably use a heavy duty strap over. I thought about those eyelets but after the rebuilt, I did not want to drill additional holes into the transom if I don't have to. There are none under the platform. I would know since I sanded every inch off to get rid of the anti fouling. As you can see, the eyes are on the side of the trailer
dingbat
I agree. Thats why I did not use them
I’m surprised Century doesn’t use backing plates under their cleats.
What do you tie your anchor line to?
All five of my cleats are fully backed with 1/4” alum plates. They are not going anywhere.
Chris1956
If your cleats are not strong that is a defect. Suppose the boat is tied to a dock during a storm? They need to perform under those conditions, as the OEM has no idea that you will trailer the boat.
If you do not have backing plates, I would recommend they be installed.
JimS123
Not a "defect", just lousy boat manufacture. I have actually seen boats with not only no backer, but they were installed from the top merely with screws!
Adding a backer is sometimes nearly impossible. Especially on boats with an inner hull. Somehow you have to be able to access the back side.
webbcraft2150
My 2150 Webbcraft only had tie down points above the integrated swim platform. Not a good choice. I travel with the drive up. I ran my heavy duty rachet strap from the trailer tie down points over the large “guide ears” on the transom plate. Cinch er down tight. Have had no issues. Holds good. I just have to make sure I take the strap off before dropping drive.
jonesg
[IMG2=JSON]{"data-align":"none","data-size":"full","src":"https:\/\/forums.iboats.com\/filedata\/fetch?photoid=10657039"**[/IMG2]
That strap looks terribly flimsy, I used a 3 inch wide version with all metal ratchet.
Chris51280
Ensign
As mentioned JimS123
