I have a 1988 17FT cajun bass boat with a 1988 90 hp mercury oil injected outboard. Ireceived the boat not running. I put a new switchbox on the motor and then had the required spark that i needed but since the boat sat around for about three years the carbs were gummed up.I rebuilt the carbs and flushed the fuel tank replaced the filter and rebuilt the fuel pump. put the boat in the water and it went with a little bit of hesitation and it took awile to get up on plane but it ran 53mph.I then took it home.two weeks later went to take boat out and could not get up on plane no way. it's very dead as if it were dragging an anchor I watch the rpm and it only gets to about 2800 rpm but when out of the water it spins as much as you want if you know what I meen some times it goes some times it dont please help have to young boys that would like to go fishing.
