Four Cylinder Engines (Without Quick-Start)
1978-1987 85-140 HP Dual Power Pack Engines
Service Note: Please use the Factory recommended spark plug (currently Champion QL77JC4) gapped at 0.030?.
NO SPARK ON ANY CYLINDER:
1. Disconnect the Black/Yellow stop wire(s) AT THE POWER PACK(S) and retest. If the engine?s ignition has spark, the stop
circuit has a fault. Check the key switch, harness and shift switch.
2. Disconnect the Yellow wires from the rectifier and retest. If the engine has spark, replace the rectifier.
3. Check the cranking RPM. A cranking speed of less than 250-RPM will not allow the system to spark properly. This can be
caused by a weak battery, dragging starter, bad battery cables or a mechanical problem inside the engine.
4. Inspect and clean all engine and ignition ground connections.
