Boat wont stop beeping!
josh9676
I own a 94 nitro with a 150 HP mercury. Recently i went out and my starting battery was dead so i swapped it with one of the trolling motor batteries and started it. When i started the boat, it was fine, then as i drove the boat around it started beeping, then stopped, so i thought nothing of it. The next time i took it out, as soon as i started to crank the motor it started beeping, and hasnt stopped since. I replaced the Temp Sender and the two thermostats, even though it has good water pressure and is pumping water good. The water is pretty warm, but it isnt like burning hot. I am thinking it must be somthing electrical, and its not overheating because it starts beeping before the boat is even started. The motor smokes when you start it so i know its getting oil. You guys have any ideas on whats making it beep?
j_martin
Re: Boat wont stop beeping!
A solid tone is overtemp. A beeping tone is the oil alert module.
What kind of engine is it? (carb, EFI, etc)
What tone do you hear when you turn on the key, and when it alarms?
John
joed
Sounds like the oil tank low alert.
j_martin
I'd be glad to offer an expert opinion.........
When I can know what I'm actually talking about, ie motor type.
josh9676
hey guys, sorry we have been having horrible computer problems. the motor has carbs on it and is a 6 cylinder. i believe it is a 94. So far we have put thermostats in it, temp sender, oil sender, redid the entire lower unit, and it is still beeping. it isnt the constant tone, more of the beep beep beep. I checked all of the oil levels and it is full in both the bottom and the top tanks. Any advice will be greatly appreciated! sorry about the long wait on the reply
josh9676
I am not so positive it is something electrical anymore either, i guess the boat could be sensing the oil pump not spinning when I am trying to crank the motor over. I havn't even started the boat and it is beeping while i am cranking the motor over..
hkeiner
I copied the below from another post on this subject. Perhaps it will help you.
If you are having a problem with the alarm beeping at you on your Merc and you know it has oil in both tanks, here's a step-by-step to diagnose the problem. First of all, run the engine on a remote tank of 50:1 just in case you DO have a failure.
Run the engine to recreate the conditions sounding the alarm. Do these tests while the engine is running and the alarm is beeping. Be careful- the flywheel is very close to your hand. Keep sleeves, watches and other objects that can catch on the flywheel away. Once the alarm starts, I would first unplug the blue wire from the oil reservoir cap. If the alarm stops, either the oil level sensor is bad or the level is low.
Next I would disconnect the green wire going from the alarm module to the #4 coil wire terminal on the switchbox. If this stops the alarm, either the rotation sensor is bad or the pump isn't rotating. If the alarm does not stop reconnect the green wire and unplug the white and blue/white wires to the rotation sensor. If this stops the alarm, check for no spark on #4 cylinder. If the alarm does not stop disconnect the green, white and blue/white wires. If this stops the alarm, then either the pump is not rotating, the rotation sensor is bad, or no spark on #4 or the alarm module is bad.
If the alarm still does not stop, disconnect the solid blue, blue/white, white, and green wires, if this still does not silence the alarm, then the alarm module is bad. You will single out a bad component in each step, eliminating each item as you go. You can check the rotation sensor by checking its output. Turn the key on, leave power wire connected and rotate the engine. You should get 1 pulse of 5 volts for every 2 rotations. You'll need to have the plugs pulled for this test so you can turn the engine safelt and easily.
