My boat has a '91 merc 3.0. I had it on the lake a month ago. Its starting to get cold so I went to winterize it today. I cranked it for maybe 10-15 seconds and it wouldn't start (not unusual, it hates me). I stopped cranking to give it a rest as I usually do, but when I flipped the key again it just clicked.
I found that the solenoid is clicking but I get no voltage on the output side that runs to the starter's start terminal. So I presume the solenoid is broken.
I jumped the solenoid (with the ignition key in the off position, and I *think* the on position) and hear the starter engage click but then the wire started making bad over-draw noises and the motor didn't turn. Yikes.
I removed and bench tested the started and it works like a charm.
Realizing the only difference is that I didn't have the 'R' ignition terminal connected up on my starter on the bench, and did on the boat, I removed that wire and jumped the solenoid again and my motor turns over.
I'm baffled at what is going on. From what I understand that terminal is an output to provide 12v to the coil (which also has another wire going to it).
Since the boat was turning over and just didn't want to start before this started happening I can't imagine any wires could have magically moved to the wrong place, but if the solenoid is bad something else could possibly have shorted out or who knows what.
Any suggestions on how to proceed? I'm tempted to try leaving that wire from the starter disconnected, but I'm skeptical if the boat will even start if that it what provides the power to the coil (whats the other wire for then?). Maybe something is wrong w/my coil?
Thanks for any pointers!
