jigngrub
- Joined
- Mar 19, 2011
- 8,155
So I met forum member hadaveha back in the spring on this site and he just lives a few minutes down the road from me.
David shares our passion for boats and is a verifiable MBS case, but not just any boat will do for this guy. He has a certain criteria they have to meet, they have to be 1. Old
2. Inexpensive
3. Must show a certain amount of rot and decay
David has grown partial to one of his boats in particular, a pretty nice 1960 Lone Star runabout tinny and wants to reconfigure it to better suit his needs and asked me if I'd help. Since I love working on boats, it was an offer I couldn't refuse.
The overall design is still in the planning stages right now, but he has decided he wants to cut out the closed bow and put in a raised deck with storage below and a pedestal seat. We started cutting out the closed bow today:
After making a bunch of racket and aluminum shavings with a jig saw, grinder, and sawsall we ended up with this:
The red line indicates where the top of the new deck will be. The crossbeams you see won't be removed until the new deck framing is installed for support.
In the planning stages are:
1. Raising the main deck 1 1/2" or so to remove a step-up in the forward area.
2. Center console or maybe side console, we're still looking at that
3. A smaller rear deck and new transom wood
4. Floatation foam
The lack of floatation foam in this boat is typical to the decade it was built in. the largest concentration of foam I've been able to find in this boat was under the covered bow:
2 billets about 12" wide x about 4' long, and 4" thick suspended under the closed bow for a floatation value of about 160 lbs. of floatation.:faint2: There's a little more foam in a couple of other spots and with some luck we might make it all the way up to 250 lbs. worth.
So in exchange for all of this back breaking labor I'm fixin' to put forth, David has agreed to part with one of his vintage treasures:
A 1967 MFG Corvette CV 15 with a 1967 Merc 650
It has a little soft spot in the floor:
David with his hand over the soft spot.
David making a hole in the fiberglass cloth with his hand.
David digging through the tiny bit of mulch in the small soft spot with his hand.
EDIT - Inflammatory remarks removed.
... but first we need to get the Lone Star in good shape, so stay tuna-ed.
2. Inexpensive
4. Floatation foam
