boat
ringo111
hi have a 17 ft sunbird saturn with a sealed fibreglass floor how can i tell if water is leaking thru hull if it has no drain plug .thx
weigh the boat. However I have never come across a boat that doesnt have a drain somewhere. in your case, bottom of the transom just above the keel.
ringo111
it has one level with top of floor,are you familiar with sunbirds.wonder if it is all foam underneath .a leak could also make it very soggy
the foam should be between the stringers, and between the hull and deck sole
