OK Boatist<br />Here goes, I'm going to keep this simple so the non-electrical gifted can follow.<br /><br />In the split second that the ignition goes to ON position the coil is energized, the voltage goes to <br />the condensor and it is energized.<br />the key hits the start position, and the engine turns over, the points close and up to 45,000 volts goes to the spark plugs.<br />1. The condensor has received the full voltage from the coil correct?<br />2. Since Mr. Lux said that 300 to 400 volts can arc open points, would this amount of voltage be stored in the condensor?<br />3. I never paid much attention to this component in my life, can it deteriate with age like any other capacitor?<br />4. Since it runs hotter in a boat than in a car, would its life expectancy be shortened?<br />5. During the boating season, this component sees a lot of use, and abuse, gets a 5 month break<br /> then the cycle starts over again.<br />6. So in your opinion should this item be changed yearly?<br />7. As the rotor goes from distributor terminal, to terminal, is not the stored energy in the condensor<br />depleted and must be recharged by the coil?<br />Yes I know that they can last a long time in cars, but when I talked to some of the old Grand National<br />guys, I was informed that a points ignition system was never designed to be used in high RPM applications, that the auto makers designed this item for the grocery getters running up to 2500<br />RPM. After each race they would install new points, condensor, coil, some even doubled the springs <br />from old points to control bounce. <br />One old book I read said that condensors can partially fail, [this you and I know] could this reduce<br /> the voltage to the plugs, and stop the engine from attaining it full RPM yet everything else on the engine checked out OK? <br />[There was even some type of machine invented to check auto condensors.]<br />Over the years I have seen engines where every thing was as perfect as humanly possible, yet I could not get the full RPM's out of the engine. Engine cranked perfect, dwell was on the money, plenty of fuel and pressure, compression perfect, but for some little reason the engine would not<br />attain its RPM potential.<br />What do you think ? Is this an over looked item when trouble shooting full RPM potential?
