I have a 90) v200 merc S # oc219197. I just mounted it. When you first take off in the morning as long as you dont idle for a long ways it runs fine.Then once you run it or put load on it it wont take off. You can rev it real hard and then put it in gear and it usually takes off. Its worse with a load. Once on top it runs like a champ but seems to use alot of gas. I cleaned the carbs, put a new bulb on, new fuel filter, checked the lines and changed the fuel pump. The jets are all correct acordding to the book. It has WH carbs. It has orifs in the front of the carbs which I thought were back draft and idle air jets. Are they not? They are in a strange pattern. They are all the same size. I thought starboard side was idle air and port backdraft. But they are arranged like this. X being orif. <br /><br /> Xo<br /> XX<br /> oX<br /><br />I thank anyone who helps alot. Peace to all and thanks!
