I have a 85 Rinker I/O with the Merc 120 in it. I had this very annoying bog when trying to takeoff from a stand still and after reading on here that the carb was a very well known issue I placed an order for a few things.
So I ordered new plugs, fuel filter, electronic ignition conversion since I was tired of dealing with points and a carb rebuild kit.
I figured I would do all these before I rebuilt the carb. The engine has never run better. Idles at 800 rpm, WOT is 3000, timing is 8*BTDC which is spec. and the engine is just plain smooth. I took it out and I still get a slight hesitation every once in a great while.
Now is there something else I should look into because I don't want to rebuild the carb if it is not needed. Any suggestions where to go from here?
