vorsprung
- Joined
- Jul 4, 2023
- 9
I have a 2000 Johnson J150PLSSC that bogs/stalls/dies at holeshot, I pretty much have to feather it past 2000 rpm and then it runs like a banshee at WOT. I've noticed a pattern though with this issue, it happens after the engine is fully warmed up, not when it's cool. It still doesn't idle the greatest but it does start everytime, the low speed needle valves were all varying turns (4-10), I've now set them all to 5 turns.
So far:
- Rebuilt Carbs with OEM parts (verified float height)
- Replaced Vapor Separator Gasket/Needle/Seat/Float (verified float height)
- New Primer Assembly
- New Champion Spark Plugs, CDI Wires and Coils
- New CDI Optical Sensor
- Mechanic inspected Impeller (pees just fine) and compression test checked out
- Rebuilt VRO with new OEM pump motor/diaphragms/oil bulb/oil tank filter
- Verified no ASV valve off the tank and checked for any cracks in the pickup tube, replaced all fuel lines, bulb, and fuel filter.
- Took off both Throttle Bodies, cleaned and put in new gaskets
- Verified rectifier is working at specification.
The only thing I found new today was that the stator has higher than specification resistance (0.60). Spec is 0.05-0.19, could this be a possible root cause of my problems before I drop $400 CDN on a new stator?
So far:
