metsfan3197843
- Joined
- May 2, 2011
- 156
left the dock today and after motoring through the no wake zone and letting the temps come up and stabilize I dropped the hammer to get up on step. As I was ramping up I noticed the tach going crazy and then the engine bogged down and I shut it off but it would have died on its own. I assumed water in the fuel as I’ve sucked out about 6 gallons recently and I didn’t try to restart because getting the water out of the rail was a real PITA. I limped in on my kicker and went home and pulled the filter. I was shocked to find not a single drop of water. Bled out the rail and zero water there also. So my questions are can the crazy tach cause any engine issues and if not any thoughts on the issue? I know I need to check fuel pressure and I have the gauge to do that but need to be on the water not the hose to see what it does under load. I Read the ECM and no codes. I reprimed the fuel system and she started right up and ran fine on the hose of course. Maybe need to do cap/plugs and wires?
thanks for any help
thanks for any help
