Baylinercapri1987
- Joined
- Sep 7, 2006
- 198
I have a issue with my boat engine right now, Bogging down off idle, and backfires when I try to give it gas. I have replaced the spark plugs, fuel filters (carb & separator), Checked the timing belt/distributor placement & everything is aligned, Timing is right at 10 as it should when its idling. Checked the compression, its all good and even.... I took apart the carb and cleaned it with carb cleaner.... Idle got better & not as much backfires but still does it. I am thinking fuel pump or something is going on with the carburetor.... Any ideas?
