Bogging Problem help please
stoked not
I'm having two problems but I'll only talk about one on this post. 1992 Johnson 225 HP is bogging when I run. She to idles fine. She will drop RPM's when I run the throttle up to 5 MPH then it speeds back up. She does it at all speeds. Not sure if I have a fuel problem or electric problem. Here's what I have done so far.<br /><br /> When she bogg's I pump the primer ball, push the choke, no change. Ball feels good<br />checked for spark in the driveway while on the ear muffs, all six have spark.<br /><br />Installed a new primer ball and water seperator filter. No change.<br /><br />Vent on gas tank appears to be clear.<br />Good compression on all six.<br /><br />Do I have a fuel, electric, or timing problem?
clanton
Re: Bogging Problem help please
Are you checking the spark with engine running and up to operating temps? Checking the spark at cranking rpm on cold engine and less then 5 seconds will not check the run timer sensors, only the Quick Start sensors.
stoked not
I'm checking saprk @ idle speed when she's warm. I EVEN CHECKED IT @ NIGHT FOR STRAY SPARK. I recently dropped it off at the local mechanic. I'll let you know what they find.<br /><br />Stoked Not
BRIAN03
Check and make sure the trigger is moving. It sounds like it stuck. No advance will make it fall on its face.
drano
I had a similar problem with my 200xp. It turned out to be the timing basin. I had to replace it. B like it was said if no advancement, you might have a problem. <br /><br />Good Luck
