Bogging Problem Solved
MtnBoater
Hello,
POsted a while back about my bogging 3.0 merc. I didn't get any replies, but I found the problem on my own and got the boat running great. Thought I'd post this to help anyone else with a boggy 3.0 liter.
The problem was the accelerator pump inside the carb, there is a screen inside and it had some junk on it. I don't think the plunger was operating smoothly either. So upon investigation, I found that the pump was barely dribbling gas, not a nice fine stream it should've had.
Long story short, I cleaned the accelerator pump, cleaned out the float bowl and all the jets while I had it apart, and put it all back together. Now it has awsome throttle response and immediate power to pull someone up.
Total cost: $4 for a new gasket. :)
smarks
Re: Bogging Problem Solved
Good News, Thanks for sharing your fix. Hopefully it will help someone down the road.
Steve
sltintexas
Where do you get just the gaskets? All the places I've looked only set the whole kit..... or a whole gasket kit which is just as much as a carb kit.
