Re: bogs down at WOT
have the same problem with my 89 60hp vro.ran fine at 3/4 throttle for 15 min then started to loose power ,had to go to full throttle to keep same speed,then lost all power and had to keep throttle wide open just to keep motor running at 2000rpm .was also running on premix 50:1.junked vro pump and put a new standard pump on it think it,s a johonson v6 pump,cleaned coils plug leads,changed plugs.water pump and new thermostate, as sombody had removed the core so it was always open and the pee hole water was always cold .had to mod the peehole outlet on lower side of exhaust to top of block as the motor could be starved of water on upper cylinders but would always shown an outlet stream.check yor fuel pump is pumping out fuel.am testing mine at the weekend and will let you know how it goes.
