Re: Bolt size for flywheel removal? Force 120 L Drive Prestolite
Not sure on the size, but when I pulled mine, I found some that fit but as I tightened up the puller, they stripped right out. I used a harmonic balancer puller which came with bigger bolts so I just CAREFULLY drilled out the 3 on the flywheel and tapped them to the bigger size.
